You were too busy eating dick
Need to go back to sleep
what?
on topic of movies. I booked twilight for the missus. shes been hassling me about it for a while. booked gold class so i can enter, and sleep for a good couple of hours..
I think flynn might be jelous that im not appreciative of his skinny white boyfriend. :nyaanyaa:
Sleep at work?
Maybe, but got some meetings today to prepare for
what?
Pretty sure my missus will want to see that. Saw the ad, looked boring. Did not see one scene of action :/
Do you want every customer in the restaurant to come and thank you? I'd imagine that would get annoying and interrupt a busy kitchen.. Then there's the health & safety issues of customers coming into the kitchen.
If it's just celebrities, seems like ego stroking to me
I never go and thank the chef at a restaurant and I don't think I'm rude or lacking manners
e
it's an open kitchen that you have to walk past to leave the venue.
you have to come within 1m of the chef on the pass and are looking right at him... MOST people have the manners to give you a freindly nod, or say a passing thanks. however most celebs are too god even for this
Couldn't of put it better my self :)
The only way In Time could be fully enjoyed is make a drinking game whenever someone says "time" in the movie. You will be drunk halfway through the movie and most likely dead at the end of it.
There were two things that made me want to see this movie: 1) The premise sounded interesting. The fact that it's about people living off time, with the rich living forever and the poor living off borrowed time is a rather thought-provoking one. And 2) I like Justin Timberlake. What saddens me is that he just wasn't very good in this movie, as he and the dowey-eyed Amanda Siegfried both just seem so bored throughout the entire movie. They have zero chemistry and I'm even going to say that they are just as bad as Anakin and Padme in Star Wars. That's the lowest bar you can go in the chemistry lab.
Not only did Justin Timberlake seem bored, but he also has a hard time conveying certain emotions. Take the scene where his mother dies in his arms, for instance. Wasn't convinced, Justin. His crying felt forced and it was. After that he vows revenge against all the time people, and risks being chased by the Timekeeper (the always awesome Cillian Murphy), and after he is given a decade worth of time from someone who is tired of living, he meets up with some rich people and kidnaps a rather high Amanda Siegfried and then starts taking time, and giving it to people, you know, like Robin Hood.... except with time. They work together, bored the whole way through, and they try to convey emotions like love.... because if you have a guy and a girl on screen together, you have to make them full in love. That's Hollywood 101 right there!
This is really disappointing to me because I expected better out of In Time. What I got is pretty much a boring movie, with a premise that sounded interesting but then it turns the movie into a one-note-wonder. If I could turn back time, I would have seen Puss In Boots instead.
what?
i laughed so much in the second one i nearly got kicked out of the movie theater. the gf at the time wasnt too happy with me either lol. srsly what the f**k kinda vampire glitters? and is a f**king virgin?
Obama in Australia=
27 cars
5 planes
1 helicopter
100 secret service agents
numerous rooftop snipers wherever he goes.
lol i heard that they left most of the timesheets for the agents checking out possible places he's gonna visit in an unattended van in the cbd. security fail
hahhahahah i think the same thing. but i havnt taken her out in a while so i thought i may as well suck it up
Australia would be a perfect place to assassinate. He IS number one on Al Qaeda's hit list, and those kunts can be anywhere.
inb4 Al Qaeda is an American fabrication.
Guest
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
