That said... I noticed last night on the way home that my Oil Pressure is sitting on 1kg/cm2 after idling for a while at the traffic lights, it comes back up to near 4 when driving, 2-3 when cruising at 2000rpm.
And it was like that again this morning.
Is this too low? I'm not getting any warning lights, will check my level at lunchtime :/
Edit: Pic for reference
guage/sensor is farked. quite common on 33's and knowing nissan its prob the same gear in 34
that would be reading just over 2 BTW... not 1
That is just a google images reference picture of the gauge, to aware people to where the numbers are on it
Mine's halfway between 0 and the first line, only after sitting at idle for quite a long time.
Any idea of a decent Martini Oil Stockist in Eastern Burbs or near Cheltenham? Do normal stores stock their stuff?
My last oil change was done at RTR, don't really want to go out to Dandenong to get more...
Unused martini oil, then switched over to Motul 300v. The difference was quite noticeable (or placebo effect) haha
300v a bit extreme for your needs isn't it?
Just go 8100 brah
100% sure.
otherwise i would not have had enough/too many left..
plus, how could someone push a wedge through solid wood if it were drilled correctly lol anyway, its done now.. let hope it lasts more than a year lol
Shoulda gotten justin to buy it at a discount and assemble it :P
Guest
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
