Vic Wasteland Thread
R31Nismoid
Thankfully I got extra battery an that still paid to much can't remember the brand goes fkn awesome but yeh massive waste of money.. Novelty wore of in about 4 minutes
Well that could have come in handy last night
How "could" it have come in handy? You either wanted a free large popcorn lastnight or you didn't.
/blacknwhitebirds
Speaking of free shit, if any of you recall telling you guys to open a CBA Goal Saver just to deposit $200 in it to get $50 cashback promo like 2 months ago...
Well that just got deposited into my account. So now I'm just going to close it. Boom. Free $50. You're welcome (anyone who listened to me).
If I recall correctly your logic was horribly flawed because involved transferring all your savings across, thus missing out two months of interest for the sake of $50...
/blacknwhitebirds
dud you need to get laid. chiiiiil winston
$200 for one night, brah...
inb4 whore jokes
ill finish it one day lol. I have an rc helicopter. That things f**king terrifying
People used to think I slashed my wrists with all the cuts I got from those blades
please enlighten us on how to get $25 a month interest from $200?
cliffs;
> open cba goalsaver by certain date
> ensure there is $200 in it by certain date (note after that, there need not)
> collect $50
> close acc
How can it work "well", it either worked or it didn't no?
lol worked 'well' as in i didn't actually have them liked on facebook I just showed them this PDF from ozbargain and they just scanned it through
gyming tonight bro?
Guest
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
