17x8 235/45/17
17x9 255/40/17
But you know this already and you're probably outside my house about to pick them up by now...
Edit: He was outside about 30 seconds after I posted this ^
SAU Brah's helpin each other out yo
das good he's sorted.
unless rwc guy wants stockies, then...
text me if he still needs them.
If rwc guy wants stockies... then he needs to find another rwc guy, because that's got nothing to do with the Road Worthy Requirements...
Considering the RWC legislation in relation to rims/tyres states that the track width of a car cannot exceed 100mm and that R34 rims are 17x7.5? and 225mm tyre. Good luck with your RWC goals of 2013
I called him before because I thought I was being spammed. He's in hospital with some sort of serious chronic flu, was causing him to have seizures and black out n stuff. He's getting better, he's just bored now
Had a discussion with couple of mates earlier, they assured me it won't be the case.
But I'll see how I go tomorrow.
Shit.
Get well soon Hamish.
Aussie citizens stuck in an escalating conflict.
How to get out and come back?
Dads in syria with his mum. grandmas on her death bed but he may have to get out of there pretty fkn soon...
f**king arabs.
Your fault Aayayron, you must be the carrier... :P
Hey guys... Still in hospital with enchiphitis (viral menengitis)
Basically it's an inflammation of your spinal fluid and the fluid around the brain. It keeps expanding and squashes your brain.... Feels like your head is in a vice :/
Neurosurgeon reckons I was just unlucky.
Had a lumbar puncture, something close to 100 blood tests, a couple of MRI's, 6 CAT scans, X-rays, if antibiotics and morphine 4 times daily since Saturday.
Had a seizure on Sunday and didn't know what year it was / couldn't speak properly.
Should be out in a week if all goes well!
Da fuq??
Its something you probably haven't heard of /hipsterhamish
Get well soon brah.
Going from a 17x7.5+40 to a 17x9+38 you only get an additional 20mm of poke either side, so 40mm is plenty legal.
Sheeeit, feel better soon hamish
f**king arabs.
Fek! I hope he gets out ok
Whoops sorry
tyre/rim combo must not exceed 15mm sorry. End of the day depends how much of a kent the RWC guy is
Also get better Hamish!
AHHH Hambo that sucks :(
meningitis is some serious shit. get well soon big guy.
thanks guys.
looking at the bigger picture. I hope the us stands down and a possible ww3 is averted.. shits getting really heated
woah.. thats some pretty scary stuff.
hope you get well soon man.
finding out if import monster have any TE37SL's in stock and if they do I'm going to try and get my deposit back from tyrepower hawthorn and go out and buy some straight away, I'm so over waiting and being stuffed around.
Guest
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
