Thanks for the input mate. :). I do think it will be hard to sell down the track.
Personally not a fan of any of the GLs or MLs or even the boxy G series really lol, but it is a present that my brother and I are getting for my Dad, as he loves the G series.
Can I has a gift too?
Agree never rated ml/gl till the new one just came out if I needed a 7 seater be hard to go by a boss q7 having said that.
No worries!
The third party auctioneer does a valuation on it. Based on that we compare it to red book and glasses guide, and set a reserve on it. Try and get the best price we can so the debtor pays less on the shortfall.
If it doesn't meet our reserve its usually dissapproved for sale, but if its been up a few times with minimal bites, we may drop the reserve, or negotiate with the highest bidder..
Too many things come into it though, like the type of auction (luxury or prestige or general etc) then market flooding.. So say a fleet goes under and 10 of the same car have to go up for sale in the same auction, then they will obviously sell for less..
Thanks mate.
That makes sense then, I guess it comes down to the vehicle on the day and the interest shown.
lol.
Yeah they're nice.
New Range Rover Sport comes out around November- Supercharged beast mode available.
Range rovers are massively awesome a guy I know had a supercharged vogue reckons it was a massive headache but looks so hot anyway lol
Yeh looking at the evouqe gives me a headache too
yea buddy!
964253_10152166616069377_1422485134_o.jp
(wasn't me who used some instagram style shit brahs)
Noice! I wish I hadn't had work today, so I could've gotten out there!
Also need to clean/lube chain, always keep putting it off/busy :(
Bike looks great :D
Bike looks great :D
Yeah I gotta clean/lube my chain actually,
I'm amazed at how fast this beast can hammer through the hills actually -_- me and a mate on R1 were REEFING lol
Other bike was a 250 :D nice bike tho
Edited by UNR33L
i wish more modern cars look like the evoque. at least its a little original.
japanese styling at the moment (for normal-ish cars) can go suck on some gonads
Lol you have a thing for girls cars don't u
Mohsen logic: buys turbo and disregards rules. Doesnt drive turbo.
just apply to Vicroads saying Nissan equipped it with turbos to increase fuel efficiency. its a 4 door lol so you might have a chance and say you have many younger cousins to transport around
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
