Fark, living solo costs a shit load. Everything is converted to wheel value.
Could have had plenty sets of nice jap rims -_-
Fridge & washing machine is a good set of rpf01's
sort of know that feel now, living by myself at home ATM while parents are travelling I like it
still only really costing me food I suppose
Pretty much my permanent situation. Folks are hardly home and were even talking about moving to elsewhere and leaving me the house = free house fkyeah.jpg
Currently house sitting for a mate in Carnegie at the moment, so I get to enjoy rent free loneliness for the next 3 weeks. Dat pasta every night haha
I cooked some ravioli last night, was delicious. Best thing is it'll last 2 days being just you.
We don't have a dish washer though, dat washing up every time feel :( #firstworldproblems
Did 1000 steps tonight pretty farken hard, didn't stop I guess this time.
Edited by UNR33L
I've got no problems doing the washing up when you're by yourself... When you're cooking dinner most nights, there's a bunch of waiting around in the kitchen when it can be done anyway... few dishes at a time and it's done and away...
Better than a dishwasher that's got dirty plates sitting in it for 5+ days getting stinky as hell because it's not getting full fast enough...
what if it means driving 50kms?
Mini road trip yo.
Hey guys I finished off my RSR's at DECA over the weekend... going to go out now and chuck my 17's on for the time being...
Any ideas what I should be looking for (rear only, fronts are still pretty good)...
I've got a quote for 2 x 265/35/18 RS-R from OTR for $260 each, fitted and balanced to Off-Car rims... In stock now...
Anything else I should be looking at for ~270rwkw...I do ~350km/week in peak hour, so something that won't just be burning money while rolling along would be nice, but grippy enough too... I don't want it breaking free in 2nd in the dry without a clutch kick or massively hard shift...
I was very happy with the dry grip from the RS-R's but I wasn't real happy with the wear rate and I've been told they go off pretty quickly when you track them
Edit: 255 18's are also a possibility, 265's on my BBS rims (9.5") have got a little bulge so could easily drop a cm of width......
Aldi has washing machine this week, 399.
I get paid weekly, so I convert car parts to weeks
lol my standard go to meal, so easy and lasts days. I also love a big fk off 2kg lasagne you can keep reheating.
And yeah, mate doesn't have a dishwasher either, gonna first world sook it up.
Should come crash there one night, it's 10 mins from your work!
Nice, I'll keep that in mind bro
  • Like 1
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
