If you consider road noise when choosing tyres you either:
- have a shit flowing exhaust
- need to grow some balls
- enjoy masses of penis
This.
so who's keen on bbh?
Wednesday night. 8pm @ song huong
71 alfrieda street, st albans
Or you can meet at mine, 6.30 and we can all roll out from there.
is that you, optimus prime?
  • Like 1
Says the guy who sold his 33 for a "family friendly" car.
So how much would I be looking at for a locallly bought set of NT05's in 265/35/18 or 255/40?35?/18
I've just chucked my 17's on the back, I don't really want to be rolling for too long with mismatched wheels :P Was hoping to drop off the rims this week somewhere, then pick up later in this week,,,
Don't really want to go anywhere over $275 / tyre... So "AD08 territory tyres" are out, no good for a daily anywhere with their wear rating...
Look @ eBay.
Yah its saying $550 + $45 shipping from Syd + like $30 to strip and fit them both at a tyre shop if you byo tyres, so would work out to be like $312/tyre in the end :( vs $260 fitted for the RSRs :/
sort of know that feel now, living by myself at home ATM while parents are travelling I like it
still only really costing me food I suppose
haha, deff save up for when you move out.
Still need to buy coffee table & tv entertainment unit. That will be $800 right there ~_~
Ive still got a whole kitchen and fridge to fill up now. All that shit adds up quick haha
Not to mention a dining table and book cases, side tables, other bullshit like that.
Just bought a Billion 7800nxl, looking at mating it with a qnap ts-220 & wd live. (that shit is like $500 excl hardrives ~ $700?)
Needs more Dezz ymcmb. He has sorted out solo living haha
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
