If you consider road noise when choosing tyres you either:
- have a shit flowing exhaust
- need to grow some balls
- enjoy masses of penis
+1, traction should be number 1 priority.
haha, deff save up for when you move out.
Still need to buy coffee table & tv entertainment unit. That will be $800 right there ~_~
Ive still got a whole kitchen and fridge to fill up now. All that shit adds up quick haha
Not to mention a dining table and book cases, side tables, other bullshit like that.
Just bought a Billion 7800nxl, looking at mating it with a qnap ts-220 & wd live. (that shit is like $500 excl hardrives ~ $700?)
Needs more Dezz ymcmb. He has sorted out solo living haha
Furniture only really adds up if you buy shit new and don't shop around. I just got a nice well made tv unit for $40 off eBay.
How the hell can any of you people have any respect for the AFL or it's gen Y douchelord players?
Like any group of people I'd there always a few that ruin it for the majority
To be at a professional level like that, with the spot light I'd say you'd need to live a fairly disciplined lifestyle
So your in?
Nah I got not much time on weekdays these days
It's really not that hard to NOT rape chicks, f**k underage girls and set midgets on fire
No different than the general population, there is just more publicity around it
Didn't realize every single AFL player did it
Need to stop hating things brah
In saying that whoever set that guy alight should have consequences thrown at him, I heard that shit on the radio this morning and its just wrong
Edited by blah_blah
It's more the fact that they always get away with it because they play AFL. Nothing will happen to the guy, will just be yet another slap on the wrist
Yeah I agree with you on that, just because you are a celebrity doesn't exempt you from the law
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
