Vic Wasteland Thread
R31Nismoid
Sigh... LPG for a power upgrade, not economy
It has a massive RON and I want to run dedicated for 240-250 rwkw, not some shitty duel fuel system.
Not to mention it will be cheaper to run and should be cop hassle free if set up correctly
Any reason for LPG over jumping on E85 bandwagon, convenience I'm guessing?
Does it also have the benefit of keeping your engine cooler like E85 does compared to 98?
From memory, it runs hotter unless it's PROPERLY setup, could be wrong though I looked into it ages ago so my memory is hazy on that.
Yum cha setups are for economy/tightarses and installer tune accordingly.
Thought about it but e85 economy sucks and evo fuel tank is the size of a coke bottle. LPG economy is the same but available everywhere.
It is also legit when you need to explain it to cops.
With intank walbro, 8MR turbo and BOV, highflow panel filter in stock box making LICP the only intake mod and a 3" exhaust with a varex this should leave me just shy of 250rwkw and relatively cop acceptable.
E85 leaves aftermarket stuff visible like injectors without the excuse of it being a non performance, legal LPG conversion and for some reason seems to be killing e7 4G63's
You're planning on dual fuel setup or straight gas?
Totally understand the convenience thing, especially evo tank aren't that big.
May have to run tanks in the boot, couple small ones on each side
Isn't straight gas legally unable to be epa'd, well that's what I heard whether it's true or not
But yeah can't run dual fuel and make power, needs to be straight gas to make more power than petrol
My accountant f**ked me
$7 refund
Anger rising
I've got a $33 due to the ATO :(
What is this? I don't even...
ATO must be crackin down. I claimed a lot and got back less than expected. oh well.
ATO = faggots
Hope you guys aren't being serious
Just because you lodge a tax return doesn't mean your automatically entitled to a refund
For your average John Doe your refund is more dependant on your employer rather than the Tax Office or Accountant
Guest
    • That is typical (for a rb at least) with a medium to large turbo, noting the format of the graph is probably misleading what you see a little (half portrait width but full height, in landscape it would look quite different) Basically until it hits target boost the torque curve is rising steeply, when that is 4000+ rpm it is not great to drive since almost all of your life is between 1,000 and 3,000 rpm. Once you hit target boost the wastegate opens and torque stops rising so quickly. From there the shape of the curve depends mostly on the cams and where they have a peak vs the rev limiter
    • Last of the maintenance items for now....not sure why but the drivers side window switch had heaps of wear on the right front and right rear switches Unfortunately, unlike earlier Skylines the controls are bolted to the door trim from the inside. So....off the with door trim. There are bolts or screws: Behind the door handle cover, pop it off from the handle side Under the rubber trim at the bottom of the door pull (also just pops up) Behind the courtesy light at the bottom. Other than that, just window down then pop off the usual selection of push in clips around the perimeter and the trim lifts up Interesting that they have a bolt on cover instead of the old school plastic held on by goop....I guess they prioritised sound levels over price Then, 2 screws and 2 plugs to replace the switch (looks identical to the Fuga/Q70 one incidentally) and put it all back together. Also much better
    • ok I understand, but the majority of turbo vehicles lose torque, or have a flat torque curve after the spool.  hence my initial misunderstanding. I didn't think this type of curve was possible
    • It is completely normal. Your original understanding is what was wrong, not what you see in the charts.
    • made with turbo and tuned by (hypergear)
