i'd come but have a midsem the next day. :/
i have two tests, one on thursday and one on friday, ain't stopping me.
unless you're doing engineering, which i am, and, then, maybe it might be smart to actually stay home and study.
lol fair enough meng. nah urban planning and design student here but yeah got a geology exam thursday and another essay and site plans on friday and monday, I is sorry dude, i'm afraid i've procrastinated too much last week. :(
Do spark plugs yourself Matt...easy job just takes half an hour with all the bullshit piping you have to remove. Get me a bottle of vodka and I'll show you how.
He didn't say he can't do them due to knowledge, he stated he had crushed his hand at work
i dont see what he did there.
is it a play on mo having a young partner? that he cant keep one long enough? that he cant get one?
im just not sure where the insults targeted.
Abbot for the next minimum 3 years.
Christian homophobe will never allow gay marriage
I've been on the weirdest drugs because of this illness... One of them is an altitude sickness drug that when taken over long periods makes you unable to recognise the bubbles in carbonated beverages and method champonoise
Thus:
Coke tastes like coke cordial
Beer tastes like beer cordial
Sanpellegrino tastes like aqua panna
Champagne tastes like wine
Etc
Guest
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
    • Hey guys, I'm reviving an old post but I'm finally getting around to working on this now. I removed the battery to get a better look at the wires and i traced the wires from the headlight to the fuse box in the engine bay, but the wiring looks fine? The wiring for the R/H headlight is 3 wires and then is bundled up with the large diameter wire that goes underneath the fuse box. I didn't take it apart yet. I know you said that its a short circuit somewhere between the fuse box and the headlight. But could it be the headlight switch on the dash? Also, i pulled out my multi-meter and set it on the Ohms, but i'm not sure where to put the negative probe and the positive probe.
