What experience/qualification needed?
book-keeping maybe?
obvious sarcasm is obvious.
Glorified PA skills required
Haha
Previously experience mainly in the use of MYOB. Knowing it inside out
I don't think you need a qualification to become a book keeper. You just become one lol
Haha
Eh...I know Quickbooks fairly well. Assume MYOB is the same shit in a different setting? What's pay like for bookies?
wallan isn't THAT far...
if it saves you close to a grand i think you can man up and pay the $30 in petrol :P
yeah wallan isnt too bad!
think how nice the drive back would be also with a nice 100K service done :D
Graduate accountants are pretty poorly compensated themselves if I recall correctly, so I expected their unqualified and glorified PAs to be on much less. If it was out east I'd consider it just for something to do while I look at longer term jobs, but that city travel makes it seem a bit unappealing.
yea i think, dont quote me, but they are on clerks pay scale. so its shite money.
Yeah anyone can be a book keeper. Doesn't use much brain power
Yeah, Grad accountants these days would be around $40,000 p.a
Book keeping position available at my work if anyone is interested
I want.
Going to do MYOB course soon so it'd be perfect way to learn the ropes, PM your work email address, will try to shoot my resume in.
Fark, Leigh gets more than that in his tax return...
Technically that isn't true. That falls below minimum wage, so work there for as long as you want on that salary and keep a log of your hours. When you quit show said log to workplace ombudsman and receive retrospective pay for every hour over 38 inc overtime
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
