you mean 12 krispy kreme doughnuts?
as in 12 of the worst doughnuts available to mankind that could only taste worse if they were filled with human shit?
AND you have to dress up like a loser?
that is, without shadow of a doubt, the WORST deal i have ever heard of...
I had the same opinion of KK donuts until I moved to the US.
(they are the same, possibly worse in the US).
Then over time somehow some of them became awesome. Mainly the chocolate cake ones. Others were still a retardo sugary mess.
But I imagine over time, KK consumes all. Dat indoctrination.
Plus you buy three or so from a Drive through with milk and it costs a grand total of about $2.50.
i cant eat shit that fake... it makes maccas look like it was carved out of the still live cows rump while you watch
Yes, it does. I too had this opinion, and before I knew it I blacked out and was eating them
Hating them, mind you, but eating them, and slowly the hate faded away..
Sitting in doctors waiting room inside pharmacy
Hear random scream outside "just give me my f**king drugs ya f**king wanker" and then a bang/crash sound
Because Main St Croydon
please.......
was moar like.
please sir can i have my medication?
franga 24 hour pharma.....
shit is wack.
your avatar bothers me. havent got anything better?
If Montana went dirty (like they all do. see Britney, Christina, madonna, Janet etc.), then what is Bieber gonna do when he goes dirty? guess he better hope he closer resembles Chatting Tatum as oppose to the McCauly Caulkgun alley way of shame.
this is what i want... i want people to go "why does he have justin beiber"
then stare into its eyes and realise its justin bean-ber....
i have a few more tho ill change it again soonish.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
