Someone needs to enlighten me on some of the pricing of foods in these Japaneses restaurants
I'm sure Hamish/Alvin knows
Particularity the pricing of sushi & sashimi
Don't get me wrong I love japanese food but where some restaurants you pay $15-$20 for a few pieces of sashimi. Im like rightio
It's a raw fish so not much prep if any is required?
So which then leads to how much cost variance is there in the quality of fish?
Because I can't taste much difference...! Between sashimi in an average restaurant and a high end one. The plate just looks prettier with a few fancy things on the side.
i just go to suzuran, and get my sashimi blocks now. i'm getting lazy. and i dont really want to deal with anything other than salmon/kingfish/cobia belly.
I love that attitude that people get when working for prestige companies...
Oh I would never drive less than a Mercedes... Even though I earn 60k and could never afford one...
Same goes for Louis Vuitton shop assistants etc
  • Like 1
lol I know
Everyone here hates chryslers especially, I love it when the comments come from the people that don't even have the slightest idea about cars.. You just laugh at them
Chrysler Neon is where its at. cult following in mericas.
good ol' NFS Underground days
jks, its a piece of shit. but would play that game if they ported it to iOS. still play Tony Hawk 2 on my phone, kick flips are bawla
gents and kents.
anyone got air con and window tinting hookups in south east?
Car air-con or home air-con?
If home I'm getting some units installed this Wednesday via a SAU member
thinking something similar to this soon...
Do eet!
Do eet!
car man..... sounds alright with the home stuff? he doing you a good discount?
Haha sure. Still learning the clutch a lot lighter than I'm used to, and about double the power of the 626 it's replacing
:D. My friend was looking to get one of these too (albeit sedan)... they look quite nice! Leather interior and comforts, yet grunt where you need it :P.
Lol lighter clutch AND more powah. Dat daily?
Lol had it all set up for the delivery but missed the mark.
Birds came in and salvaged what was left haha
Or perhaps I set it up for Birds, I know he loves his quips. Just call me the puppetmaster.
Yup daily duties, has a decent tow capacity too :) Parking was interesting this morning though, very light steering.
Will be calling vicroads shortly to find out what hoops I have to jump through
Preparing my anus for this summer
My mind doesnt usually sit in the gutter, but read this the first time round. thought you might have been referring to power bills.
Good new from Vicroads for a change! *celebrate*
If your car has been engineered/new engine number, and you have put a different motor in it... all you have to do is go to Vicroads, tell them its the same engine as the engineer, have a signed piece of paper from mechanic with new/old engine number and they'll change the details for you. So when cop checks cert, tell them to check their system details and it should all be there. wew.
Inb4 defected for everything anyway.
as long as the number follows the same sequence as stock... e.g. RB25xxxxxxxxxxxx
this is boss when you get situations like an AE71 with a 4AC motor and the numbers are just 4Axxxxxxxxxxxx and a 4AGE is also 4Axxxxxxxxxx
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
