Vic Wasteland Thread
R31Nismoid
Shut up Leigh, let's take this to the strip!
Or are you CHICKEN?
haha, was considering taking my car to DECA for some lols if I did not sure if I'd go stockies or NT05s! aka smoke or times
Take both?
I made it through 3 DECA's and a heathcote day on a set of NT05's so as long as you don't rip it on the basketball court you should be fine.
haha yeh if I do I'll just take 2 spare stockies to rip up at the end probably
kinda want to get a catback as well! but my brain is saying don't do it because of the cop harassment
how do i kill my auto? =x
neutral, rev to redline, slam it into drive
The guy is like 40+ and had it since brand new. Even though he only has one functional eye, he can drive. :P
LOL!
yea its shocking isnt it!
made a point of speaking to my non australian immigration officer (!) that i was guaranteed acceptance on a last remaining relative visa, and simply chose the partner visa because it was cheaper.
tis dog shite.
yeah it's farked
Although so far everything is going ok on our side, they took out the $5k or whatever it was from the account and haven't heard anything from them
Scotty, do you have any 33 ones laying around to suit a stock airbox? I'd love to test fit one to see if I can handle the intake noise increase, considering its my daily I don't want it too loud so don't want to buy one from you only to find that I won't be using it.
atm I've got the stock pipe with some of the flexy bit removed and some 3" zorst steel clamped in, think it could be my restriction...
LOL!
yeah it's farked
start getting evidence toghether. they contacted us a year from taking the money. ask for all sorts of shit. then a year after that is when they process the permanent part. which is what they are doing now.
I had a 4" steel intake and you could hear it but the exhaust is louder anyway... Also with the HKS turbo the sound was fkn awesome
And just how visually obvious is it? There's currently only about 1cm of the 10cm of metal pipe visible... and only from a certain angle, and its in shadow.
Could I just paint it black and have it look almost compreetrey stock?
Stock BOV not blocked off.... currently "ssshhhhhh" or "peeewwwwwwwwwww" depending on the boost/gear
How much is one of these Great Scott intakes for a valued and handsome SAU VIC Member such as myself?
Guest
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
