Vic Wasteland Thread
R31Nismoid
Yeah I'm already blacked out... Thinking of doing the shiny brassy coloured wastegate actuator as well... Its the only thing that looks out of place atm. Exhaust Mani heat sheild in a matt black heat proof looks baws compared to the rusted old look :D
haha! yea do it.......... almost contemplated doing the inside of the engine bay black too... but that would have been to much. would look good with a white car tho...
Why do you need to carry jerry cans? Unless going long distance there are plenty of United servos around Melbourne.
I'm thinking more for track days/DECA. there's a station walking distance from my place.
Not sure how fuel efficient this pulsar is, battery always gets isolated so never recorded. isn't too bad when off boost.
will get 98 tune, see how turbo handles the motor and if I want more power/boost will go E85 and GTX2871
I also have a scotty intake with a factory AFM and Airbox on the other end of it. cost was about ~250 (for me). Good idea about sticking the rubber to the outside of it for the super paranoid though..
Scotty actually painted mine black, so he's well aware of Vic paranoia
That's because when Scott has nothing better to do, he opens up every single page of SAu and goes through them. It his way of being completely informed
hahahah!
so he desnt have some sort of webcatcher like stao, who knows when ever someone says the word "hypergear"
hypergear hypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergearhypergear
you there stao?
Stock BOV not blocked off.... currently "ssshhhhhh" or "peeewwwwwwwwwww" depending on the boost/gear
How much is one of these Great Scott intakes for a valued and handsome SAU VIC Member such as myself?
The noise barely changes as the stock airbox is designed to dampen it. With a pod? Then it would be loud...
PM me for info, I don't want to upset the mods... :P
you there stao?
I heard
If you type his name three times
At midnight
He appears and strangles you with a braided oil line
Guest
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
    • So I checked this out in the weekend.. and look at this. I remember watching the videos. Finally got to see it in person! BRB. Tissues. Got tonnes of other pics and videos too.      IMG_0171.mov IMG_0113.mov
    • For anyone who might be put off by the slightly wacky wheel offset shown on the box photo above, the production models are not like that. Here's some more pics of the actual product (as well as the interior)
