Vic Wasteland Thread
R31Nismoid
related:
When restaurants receive food poisining complaints like "i ate your calamari and when i got home I was sick and throwing up" we always look up the table number and there was ALWAYS an excessive amount of alcohol consumed for the table.
not to mention that in 99% of cases you don't get food poisoning within 3 hours, if you did the food would have to be so rancid there is no way you would eat it unless it was part of a jackass segment. Generally it takes 24 hours but can take up to 48 before you are sick from food. The bacteria have to multiply to harmful levels which takes time.
There is always someone that will debate this and say it happened to them, but it will have most probably been from the previous nights dinner/lunch or that days lunch
Kinda miss perth.
Lived there for a few years.
On another note. Vomited out the window and down the entire side of my cousins navara.
Then lolled uncontrollably
Nothing to miss here brah. Might have to see a summer first though
Guest
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
