Will go looks amazing for $50
N64 are like $150 now FFS
managed to get one with mario cart for $100... ghey but since mine got thrown out by accident it had to be done :/
That's alright
@Plattsy I actually do think snes are holding more money anyway lol
and if i asked a male mate to that place, would it be considered ghey?
No, it could be two mates going out for a beer and good tucker.
This is ghey... :P
Wont be running E85 just yet if thats what you're asking. Not many documented, tracked pulsars on E85. I know of one, and his hasnt run the same since. We'll see how this setup goes with the current turbo first on 98, and will weigh up E85 later.
the courses will be small but I am hyped! That deconstructed lemon cheese am dish that is the last photo in that album is the only one I have had and it's f**king rediculously good! And to get that last time it was in a $1000+ meal
I hope it was good for you Tony
He let me go for a wild ride
no joke
Clayton aye. Close to home i'll check it out
yeah, sweet. bike riders running around like they own the roads, stopping traffic, running reds, wrong side of the road.
pretty sure none of it would have happened if they just let the dickbag in the rangie go past them instead of taking up however many lanes.
i cant say what i would have done in his situation, but it would be pretty intimidating being stopped by what looks like 100 or so bikes and having them all approach you.
i'm not on either parties side, i just think they all acted like a bunch of dick bags, (including the rangie driver) and it all could have been avoided
who is this and why is he on the fence?
As you can see, there's a bitch in his way, that he needs to move.
lost it
http://www.news.com.au/national-news/victoria/woman-dies-10-in-hospital-after-toxic-chemical-released-at-sunbury-motel/story-fnii5sms-1226732023320
For what purpose would someone in a motel release Hydrogen Sulfide and what is it normally used for?
fart gas
damn :(
next saturday.... will have to take a different lady friend ;)
I';m very happy with the Drift Ghost HD. nuff of this GoPro stuff. do need a new mic though just dont have to worry about crappy cases and skeleton things
any body wanna play indoor soccer on friday evening in frankston. theres a couple of guys needed.
ive been six times, and havent had my car stolen or been stabbed. its good fun actually.
then again if i was a dodgy kent i wouldnt try to stab me either.
Guest
    • Great interview on damper settings and coil selection by HPA https://www.facebook.com/HPAcademy/videos/30284693841175196/?fs=e&s=TIeQ9V&fs=e
    • Yeah, it was a pretty deep dig.
    • The values for HID colour are also defined ~ see https://www.legislation.gov.au/F2006L02732/latest/text  ~ goto section 3.9 onwards ....
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
