Vic Wasteland Thread
R31Nismoid
I'm guessing that's a GTA reference?
It's been over a decade and a half now since the release of goldeneye 64 but I STILL feel the urge to shoot surveillance cameras
And I still feel the urge to squish guys in my tank on my airport runway; life and nostalgia is funny like that.
inb4 Clayton Bowls Club sell a heap of parmigianas to you lot cause the guy has already left / it was all a joke on hipsters.
range rover overfinch.
maaaad.
600hp.
will destroy anything. on mud or road.
Bowler nemisis would like to disagree
Angus is peppered
Booked for 2 @ 6p.m Saturday night at Clayton Lawn bowls
Lets have a taste of this Vue Du Monde food!
sweet... post results in restaurant thread :)
I'm not booked for a few weeks
would be epic joke... would still buy parma....... because parma
If you want a parma, come to the SAU Vic monthly meeting this month ;)
Going to smash dat shiz so hard it'll start crying and pretend it didn't want it all along
typical parma broad minded person.
Was it geology with melbourne uni by any chance? I did a week in torquay there in 09, it was exactly as you described it
Yeah that sounds like it haha doing it as my breadth this sem, t'was really good. :)
Yeah I don't do Frankston or Dandenong after dark, I've seen the dodgy people there during the day... not worth the risk...
What?!
I've lived in Frankston for 13 years, and I can assure you there's worse place to be in... *coughs* sunshine...
Is the implication there that my anus is so loose I wouldn't realise if I had been raped?
Angus is peppered
Lets have a taste
Edit: These quotations may or may not have been taken out of context more than the Range Rover vs Bikers story
inb4 1/2 of Wastelands bump uglies Saturday night
i should come to more meets
I lived in dandenong for 5 years. It was probably me that you thought was dodgy
Guest
    • Wait, the flappy paddles or sequential is the small penis indicator?  Either way, I can't afford it.
    • You and me both. If I ever get it running again, I'll have to look into cruise control.
    • Yeah most people that have heard it said it was fine but it's always had me slightly worried. Oil pressure I can't remember off the top of my head but it has plenty, I run 10w60 You're probably right mate, best get ordering some shims! Guessing Nissan is the best place for them?
    • Just wanna preface this and point out I'm a mechanical fitter by trade but have had very little rebuild/machining experience, but I am keen to learn, hence this project. Bit of a write up here so bear with me, just want to make sure I do this right  I've got an rb30e currently pulled down. Planning on putting a 25 head on it and running it in my s14.  Not chasing huge power so I'm just going to try get away with factory bottom end for now.  Started measuring the crank the other day, realised my budget daytona micrometer set wasn't up to the task (surprise, I know). They only measure to 0.01mm but the Nissan specs are to 0.001mm. Anyway, I started measuring anyway and came away with the mains being inline with the oem spec, as well as the big ends, except for no. 5. I consistently got a measurement of a hair over 49.96mm, where all the others were pretty spot on 49.97mm. The lower spec for grade no.1 is 49.961mm. I'm getting access to some better gear my next days off to double check everything, but in the case that the big end is right on that bottom spec, is it pretty much just a case of straight to the machine shop for machining and oversized bearings? I understand I need to measure the tunnel as well to work out my oil clearance, but it's the different grade bearings in the manual that are confusing me. What is generally the process when one journal would still technically be in spec, but in a different grade?  Thanks for coming to my Ted talk
    • You need to visit Ipswich. Plenty of clapped out R32 and R33s running around here as daily drivers. And when I say clapped out, they're how you'd look at a VN, when it's the year 2010...
