Why do no games have 4 player split screen anymore?! 1/4 of the screen each... on a 22" TV... that was fine.... Nowadays no-one even does 2 player split screen on a 50"!
screens have gotten massive but resolutions haven't increased as fast. dat 320x280 4:3
If you could get hold of the original machinery used for a good price, then yes, if you had to make the machinery AND the games, no
kinda like how nike and reebok etc kept all thier old shit and started remaking it for basically nothing and selling it to gen y douchelords
Actually they usually have to redesign the moulds etc from scratch as all that shit gets destroyed. theey also make small redesigns to make the shoe cheaper to produce.. and ruin the sillhouette in the process :(
Sup wasteland brahs?
i like my theory better
Guys short notice, just found some wheels in Sydney which i might drive up and get this weekend. Will 18x10 +38 fit stock rear guards r33 gts-t?
XD9's... And I know I should man up and get +18 but my car is immac and don't wanna roll guards /nohomo
Edited by colourclassic
You will need to roll the 10+38 if the car is lowered. Get the guards rolled, you don't even notice the difference visually. Flared is a different thing.
Your car is immac?
Let's be realistic here, it's a 20 year old jap car that is common as a pom with bad teeth.
You aren't driving a hand painted rolls royce with a single stroke coachline that can only be painted by one guy on earth.
If you want it to look good, be a man and roll the guards... Or leave them, shred a tyre and rip the immac guard in half going up a driveway. Either way suits me really.
See where I'm going with this?
Get +18's XD9's only look good in 18x10+18 or 17x9.5+17. The other sizes all have no lip
Your car is immac?
This man knows wassup
Your car is immac?
lolz i knew was gonna cop it for that! 18x10 +38 has pretty decent lip, i'm not going for hellaflushworks, and i'd probably put some widers tyres on the rear...
Next question... Will four wheels/tyres fit in my shitty old japanese bomb with a driver and passenger?
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
