in a 33? not if they are 18x10
4x 8" will fit across the back seat but make driving uncomfortable if they have tyres fitted.
rear seat out = 4 18x10 in the back. two min jerb if you dont bother screwing down the seats every time. mig has a sedan. don't listen to him
Taxis and coupes have the same rear seat room. even without the doors it's easy, stand them upright on the back seat, you can fit 2 either side then push the front seats into them to hold them in place.
If you convert this wheel size speak into age and dick length with rubber meaning condoms, this conversation gets pretty nasty and car orgy sounding / lined with in ur endo.
Managed to fit 3 panas and 4 ad08's in the gtr once, another panas went in the boot.
Can easily put a set of 18x10 with 285's in rear seats attached.
I have always run 18x9.5 or 17x9.5 and have had 4 rims with tyres in the 33 more times than I care to remember...
have also had a 17x9 with 235/45/17 in the boot where the spare tyre goes
lithium is just a shitflamin mongrel
also I dont care if you get 18x10+38, they will look fine, but you still should be rolling your guards.
also, unless the motherfuckers are free I cant see how spending 11ty billion dollars on pertrol is gonna save you a dime.
best to get XD9's brand new from jesse streeter.
car looks good hamish
looked at another evo 8 today
asked him on the phone, whats wrong with it, smokers car etc? nah all good , no issues, non smoker
rock up
smelt of smoke, cigarette in the ash tray
wouldnt go into reverse properly
bonnett doesnt line up
rear bar different colour
both diffs clunk going at low speed around a round-a-bout
at least it had no rust
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
