F**kn lost my dog this morning.
Let him outside for 3 mins to take a piss and his done a runner, because our fence hasn't finished his found a small gap in the fence.
Dog is tagged and has our phone number on it but no one has called or turned him in yet :(
It's a new house so don't think he'll find his way back home...
Feel really bad becuase its my missus dog shes had for 11 years :(
Tony, that sucks hope you find the dog.
Drive and walk around for 3 hours trying to find dog, and making phone calls to council and RSPCA all day no luck.
Then gf's sister comes over and looks for 5 mins and find him.... What luck
Huge relief
Btw cheers for the drive last night!
R33 stockies do not fit on r34s...
No?
Huge relief
Does your gf know the dog went running?
And that's good to hear that you've found him.
Also no worries and cheers for the drive, you need real seats!
hmmm
Surely there's an app for it somewhere. Does that feature have a name or something?
hold centre button and press the off button... it is then saved as a screen capture in a dedicated gallery
also galaxy s2 pwns ipod
Guest
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
