Yeah mine are done by these guys on St Kilda road http://www.visioneyeinstitute.com.au/locations/victoria/melbourne/ they're meant to be the best in Melbourne.
I think it was a bout 5.5k it's great I highly recommend it. Going on about 2 years now.
I've heard the same about vista eyes lol
I'm looking at going to vista later in the year
Yeah i looked into most clinics in Melbourne. Price rangs from $4k to $5.5k
I have a client who does it but he charges a premium
There is a groupon offer for $3.75K but not sure of the quality
I found a reputable place in Sydney that does it $2.5k that i have heard nothing but good news. But then need to factor in hotel and flights
Genetically Superior Baby!
That man has boobs.....
Anyone know where I can get a small tin of plastidip locally? Or anyone have any that I can use a small amount of?
yep....autobahn....or The body shop actually stock a similar product now too...meant to be better ...well thats their sales pitch anyway
Interesting, not in a spray pack though? I need a tin of the stuff. The body shop? Isn't that a girls soap shop?
think i have half a can (spray) of black plasti-dip brah, can check the garage to make sure.
its also a paint supplies shop...seaford one has plastidip stuff...not sure if dandenong has it...pretty sure autobahn has it now anyway
Things I liked about Vista are they have the wavefront analysis, and rick wolfe has done shit loads of these. At the time I think it was about 6k all up, but that was 5+ years when I had that check.
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
