You shittin me? They cut your eye while your watching? Or can't see cos mostly blind prior to incision?
Yep they hold it open with clamp things cut flap, fold flap over laser and reshape eye, put flap back on. You loose vision for a little but all good.
Edited by UNR33L
sooo.. new season,
strike the blood
outbreak company both brought some lolz.
Have some episode ones downloaded, just haven't had time to watch yet!
Recently watched danganronpa which I didn't think was too bad, but apparently the game is heaps better. Reminded me of 999 game, which was pretty fun.
I heard that you can smell getting your eye burnt whilst doing laser eye surgery. Haha
yeah smells bad, they tell you it's the machine and not to worry about the smell but i'm a bit sceptical
Did you get Lasik or PRK laser eye surgery?
I heard PRK is better but has alot longer recovery times
Lasik you pretty much have the vision straight away
ASLA is a refinement of PRK
1 week vs 1 day for Lasik :-/
http://www.sydneyvision.com.au/index.php/alternatives/
Yeah i've heard mixed reports. Some people are fine after a week. Some have taken up to 3 months to heal and reach 20/20
My brain has exploded reading so many pages since yesterday from this forum. Its quite informative
http://forums.whirlpool.net.au/forum-replies.cfm?t=1258336&p=79
Lasik, I think my cousin had the other one with the implants or whatever but took a little longer to recover it depends what your eye is like.
Mine were nice and thick plenty of space to play with and do the good way.
Edited by UNR33L
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
