are verbal contracts not legal in vic?
retty sure he entered into one with you. i would not have f**king paid mate. i would have told them to change it back and pay them nothing.
Try proving it though, or spending $35 to take them to VCAT over $20. If they have invoices showing that they normally charge that for the service, you're fresh out of luck. They also have the right to hold your vehicle until payment is made.
Sucks, but yeah. Always have to get written quotes these days...even on cheap shit lol
but. but. but.
im scarey. that usually works. :wacko:
My local place fkd me last time I went in there...
I asked how much it would cost for them to flip my two rear tyre on the rim... Since they had some camber wear and I wanted to use the remaining outer tread for deca... I was told we can do that for $22... I asked "For both the rear tyres?" "Yep we'll do them both". so I was thinking "Finally a place that isn't going to rip me off".
I go down the street, have some lunch, come back and suddenly it's $44... $22 each... fuuuuuu, classic bait and switch. Said that was bullshit, and he dropped it to "$40, is the lowest we can do"
*rage*
that's why, i always pay, before the job is done.
or get a written quote if they refuse to let me pay. =P
Scary can work. I'd probably give you your $18 back...but not Simon...he's a cuddly koala.
nawww thanks babe.
simon. grow more beard/wear more leather. amazing how much shit gets done easier for you.
WL Brahs, anyone know of someone considering selling their 32 GTR? Must be rebuilt engine (preferably forged goodies and shiet). Neighbour interstate locations like NSW/SA is alright, too!
One of my mates is on the hunt for dat dere skyrice.
put a stock evo 9 MR BOV on the car instead of the atmo one that it came with to try and stop the car attempting to stall every time you come to a stop.
its so super sleeperish now, 90db exhaust + nearly inaudible BOV, the loudest thing when you rev it is the pod filter.
no need to prove shit.... i take my car... i am big
even if you are small it's pretty easy to kick up enough of a fuss to lose them another $40 customer
just came back from Lezzet on Brighton rd (contemporary The land of goat sphincter rings). was really really tasty. Wanted everything on the main course menu, got to taste 4 of them and all were good. Efse Dark Pilsener went down well with roasted pumpkin seeds.
Edit: not allowing the county the sphincter of the universe to be typed on a forum is rascist
Guest
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
