scotch and ice is a cocktail..... kinda
or beer in a glass...
Well those I can afford..... kinda
I'll try not to slum it too much...
Edit: also I wish I could have been at go karts... Should book in another in summer tym... or after mid nov, really :P
  • Like 1
I smashed that 'big kart track' up in qld last month can pretty much take that track at wide open throttle the whole time just need good tight lines
Probably helped I was a few KG lighter than the competition as well
tru dat! when is your last exam bro?
also nice new sig! han, such a baws. best guy.
umm 12th of Nov, wbu brah?
haha thanks one of my fave moments, he definitely was the best, dem feels when he died and also when gisele died. :(
spent the day welding fixing our greenhouse to run the hydroponics again this year.... Dat flash burn, should have worn a long sleeved top
need to find some time to head out your place soon. wanna play with them pussies.
Guest
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
    • I noticed that I could see creatures on the moon when I turned my new headlights on. I thought I should check the alignment. It's pretty rudimentary but I just grabbed some dry wall and put it against my tablet and made sure the beam was below the height on the headlights. Ie the beam is at 600mm on my car, I just made it lower than that 7.5m away.  Not the best but it'll do until I can do it properly at the local shops.
    • As @Duncan said - the bores are most likely to cop it. But anything can and does happen. Rods are cheap. Rods are good. The work to rebuild the motor will be 30x the price of rods. You won't notice it.
    • Yeah car has 110 on the clock. That said the front turbo (that exploded) doesn't seem to be the original, it has a S1 part number but the car is a series 3. Yep, in the cat is where I first found the turbine wheel pieces - a couple decent sized ones, then a whole lot of fragments.  I agree, probably makes sense to upgrade parts that are being replaced. Things like rods would be 'nice' but realistically it seems unlikely they would need replacing. I was hoping that it was a case that they generally f**k up the valves but not the bore, or vice versa. Is it generally the scour damage rather than ceramic bits getting mashed into the piston tops / valves? I tried a search but couldn't find any threads with pics from the guts of a motor that's had this happen.
