2 weeks... what else is there that's drawing power? you could test the current draw of the alarm / car with everything turned off
Since the battery has been dead before, it might have lessened capacity now... do you have a proper 3+ Stage Mains Plug-In Charger? Alternatively, you could buy one of those little solar panels which tickle charges when the car isn't running to keep it topped up :) Worked great for my dads old boat when we didn't go near it for a few months at a time.
yeah wil do current check when I get it back.
charger is 6 stage I think. will get battery checked this week, it's an odyssey just over a year old and I think it might be stuffed. farkin hope the alternator or start motor isn't killing it.
Anyone here have a spare coolant bottle cap? Mine went missing.... :/
For a temp fix, try a plastic milk bottle cap, they're about the same size... little bit of electrical tape around the neck if it's a touch too big...
It doesn't hold pressure or anything since there's the overflow port next to it, so its just to stop it from sloshing about into your engine bay while cornering :P
There's two of the chinese places at knox city. I've been to one which isn't bad, it's in the short "Arm" of shops on the lower level, opposite the main food court. They do pants really well, cheap and fast too. And I've had a few dress shirts altered there as well.
Was just going through old pics and found this from back in 2008 or thereabouts. Me and my mate borrowed his older bro's Calais to go for a spin down to St Kilda beach (to try impress ladies, as you do when you're 18 :no: ) and couldn't figure out why the thing was so sluggish. Opened boot to find this:
Not sure if better or worse than cutties :S
LOL. When SSSL's at the rears aren't low enough. :P
if you just need one for the weekend, I imagine the S14 one is same as volvo ones.
borrow mine now I'm out.
Need it back after tho.
Will do Martin!
You're in Yarraville if I remember correctly?
Why you party poop and no deca?
Tried a water bottle cap and it's just a bit small, milk cap seems too big. :-/
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
