haha it's loudish up in the revs under load but I like the silent killer spec atm :D
straight pipes is just stupid loud some people on forums have done it lol
Just add them on facebook and send them a message, main guys name is John I think
Dem photo skillz!
haha well at least drop the rear mufflers
Mine is super quiet atm, even in high rpm, dropped the rear mufflers and it's got some noise to it.
Probably going to remove the center muffler and 2 rear ones, then that leave 2 cats and 2 resonators so still won't to too loud
some people on ford forums dropped the rears and dam it's loud! cbf with cop bait either
But does dropping the rear muffler in the Ford exhaust allow for better flow?
More power?
Probably hardly any difference from just the rear mufflers
They do come with dual 2.5" standard though :P
So just for sound...
What's the usual exhaust upgrade for these Ford's?
Like how JDM Turbo cars, usually every owner moves up to a 3" / 3.5" exhaust...
So just all for sound...
Like how JDM Tubro cars, usually every owner moves up to a 3" / 3.5"...
If I were to upgrade my exhaust for performance next step would be dual 3" system allows it to breath a bit easier and makes more power on lower boost, much like turbo cars do from memory.
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
