why selling the HSV Plattsy? didnt think you had it for very long? finally seen the light?
nah i love it. only had it about 8 months. but the wife and i are expecting a bambino, so im moving into a 20 dollar a week micra lol
cheers man. seen that bad boy, but im chasing a 2 door! also..... 4k? is he on crack?
Ah yeah, cause your Ford is Supercharged...
So similar principle.
But you got like 370+ rwkW's, yeah..?
So what would a Dual 3" system take you up to?
maybe another ~10rwkw the main problem at the moment is stock injectors close to being maxxed out
Have to be micra?
Barina gsi/Opel corsa C
was looking at barina/corsa gsi, but cant look past the cheapness of the k11. plenty around for under 1k. sure they need work. but i need a hobby. :woot:
doooood just an N13 or N14.
congrats btw, didnt know there was a bun in the oven and youre off racing go karts. i hope she beat you with a spoon afterwards.
also, what meat? any excuse to get the car out and extra kms
370 - 380 is only 2.5% power increase, hardly noticeable and not worth the extra cop attention from the noise.
exactly why I haven't bothered yet, like dat dere stealth still has a good note to it as well
Yeah and you'd just chew through tyres even more quicker LOL!
Guest
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
