I'm entered for wrxmas :D Can't wait...
Today I put the car back to street drivability... put my normal wheels back on and the cat and amps+sub back in after Winton/DECA last week...
Jonoe, I only did a few seconds faster than you... Only got in 7 laps in the last session of the day, was popping cooler pipes for the rest of the sessions :( Would be good to learn some proper lines and correct entry speeds for some of the corners, I couldn't string anything together and get a decent time in the few laps I did have out there.
Sandown should be fun because I know the track a little bit already so I'll be a little more confident. Come along man, it's cheap as chips and a really fun day with passenger laps the whole day so some of the big boy cars car scare us silly :D
anyone know what happens if you over pay when paying your rego... I'm guessing it's creditedo, but do you have to wait 12 months to get the credit?
is it much? worth standing in queue for 4 hours at vicroads for and probably not getting much help?
anyone know what happens if you over pay when paying your rego... I'm guessing it's credited, but do you have to wait 12 months to get the credit?
I think you can call up and they refund the excess in a cheque, only sort of worth it if you paid $50 or more over though
'grats Paul
welcome to the club lol
good luck finding a k11 for cheap tho, the JDM kiddies have been onto those for a couple of years now
thanks mate! how many you got?
also! picked up a povo pack k11 ls for 400 bucks. took 18 hours of work to clean it and the interior.
needed a battery, babttery clamp, rear taillight, cv boot and a rajab damn good service.
  • Like 1
"Needed" or "Still Needs" ?
If so, I'm voting for a backyard mechanic bbq with the wasteland boys next weekend ;)
haha still needs battery clamp, service and a bloody good polish. artz is coming over saturday arvo for polish. but yea. im down for wasteland barbi at mine! haha. will need help changing cv boot!
Just the boot? May as well put in new shafts
(and an sr20)
haha. seen a build thread in england of a guy with sr20 in a micra.
its too much work...... might just get scotty to knock me up a turbo manifold..... hahaha.
also reco drive shafts are like rocking horse shit. 15 dollar and an hours work to change the boot. its the outer. so ill do that for now...
Guest
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
