140hp...damn that be a lot of stickers to give that much extra power.
your going to need decals at least, plus a shopping list, and maybe a GTR badge to get that much power.
have gtr turbo! lololololololol.
sure ive gat an sau sticker somewhere..........
pod filter and 2 inch exhaust gives me 94hp at the fly.... ok. maybe 100 hp at the wheels is more realistic... but i have high hopes for e85!
As of now? About 35k..
So a shit gtr
Lol rookie mistake. Never add up the bills. Nothing good comes out of it.
I'm into my second folder of receipts but that's 8 years of ownership haha
Still need to do a full spray which has been delayed for now....
annoyingly had to rma my new motherboard :( at least the store swapped it over straight away, gotta reinstall then straight back in bf4!
good to see Webber on podium for last race! also dezzmang you're crazy staying up for these late ass races lol
get one of these?
http://www.asrock.com/mb/Intel/Z87%20Extreme11ac/#BoxPhoto
Guest
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
