anyone know where I can find some of the white clips that clip side skirts onto the body for r33 gtr?
also the boot interior clips?
went to Nissan Blackburn - they sent me to their warehouse in Mitcham, they didn't seem to be able to help me, ended up with some clips for underneath plastic below front wipers which MAY fit..
but yeah still searching for a few..
Sideskirt clips
Skirt side http://amayama.com/search/?q=G7656-13310
Body side http://amayama.com/search/?q=76848-35F00
Boot trim clips http://amayama.com/search/?q=01553-04941
Hopefully the sucker fits Alvin, I did a fair bit of cutting on that front pipe...
If not I can just make a new bracket for it.
How does it sound mate? I asked Grant that question after doing his exhaust and he just stared blankly at me and chuckled. :unsure:
speaking of exhausts.
have you been under the back end of an evo x to see what kind of muffler space there is infront of the rear diff?
i was thinking a moderately sized muffler infront of the rear diff, a Y pipe with one side going to an electronic cut out valve then a pipe to the right tip and the other continuing the exhaust through a big ass muffler and then exiting the left tip.
so like a varex but better sounding.
I am making a similar setup, but I want it automated, so I ran a vacuum actuator.
https://www.facebook.com/photo.php?fbid=623719741023434&set=a.448399381888805.111313.448396628555747&type=1&theater
I haven't been under an Evo 10 yet. Sorry mate.
has that been tested/run yet or still in the process of making it?
the fact that it automates itself is cool, the same could be done electronically with an RPM window switch
Untested as yet.
I wanted it wide open on throttle, if the vac setup isn't great I might run it off TPS.
Where HAVEN'T you travelled to?
lots of places.
this is my list been to atm
(lots of places are multi trips tho)
Australia
Fiji
England
France
Sri Lanka
new zealand
Vietnam
Hong kong
Macau
philippines
South korea
Wales
Ireland
Morroco
USA
Germany
thailand
laos
Brazil
Argentina
vanuatu
Italy
Vatican city
Sweden
Canada
South Africa
Singapore
Greece
United Arab Emeriates
Spain
Austria
Monaco
Got palns for a few new ones next year.
Kuwait is looking good.
Maylasia low chance.
Pakistan..not sure if want to.
Egypt 50/50
Mexico high chance
as well as back to some of the usual suspects.
Macau want me for 6 trips, so lots of side trips to hong kong
USA a couple times
2 more trips to brazil, if so thinking of doing a side trip to Argentina or Chili
oha dn Thailand and prob SG
no idea what else yet
Guest
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
