You know where the cool restaurants are at home, though. Food is subjective...I've loved all the places we've eaten at...cept maybe one. Most of the world eats meat; I doubt catering to everyone's taste is even a criterion in earning a chefs hat. Hell I don't like some of the food served at some very reputable places and wouldn't even eat it but I wouldn't say the place is shit when I haven't / can't even eat the mainstay of their food/menu that they are famous for.
So go home...
Yeh amg c63 under a ton is do able but it'll have high kms
The a45 is awesome don't judge it from outside the interior is better then the c63!
I know of heaps of people with audi trouble man
There's no way in hell I'm spending $80k on a car I don't like the exterior of...
lol bikes exacerbate them. Do deadlifts; strengthen back; ride without ever getting a sore back. What'd ya do to it anyway?
No idea, ongoing problem. Have tried several strengthening things, deadlifts, medx (fancy back machine). Comes and goes. Scans show a couple of bulging discs then sometimes pinch on nerves
If they are some of the best restaurants in the world then they will cater for everyone.
One of the best things about owning/running one of the best restaurants in the world is that you don't actually have to cater for annoying-ass vegetarians or stupid requests
Will they do me a well done eye :P
Actually ate at Ash's Squires Loft lastnight...food was very good. CAAB angus porterhouse was very tasty and a good size (400gm) for the money. And shock horror I had it done medium :O
I asked for "medium rare" eye fillet the other day and seemed to come out pretty well done :\ didn't really bother me as it was a company expense but still! should of said rare!
Edited by UNR33L
Guest
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
