Yeh of course just sayin if ya haven't seen one in real life it's far better than pictures an that
Think I've seen them, maybe the non AMG version not sure... I actually like the front, it looks pretty tough, but just not after a hatch...
I thought about a VW Sirocco or whatever they're called, they have a toughness about them, but still feel too much like a girls car to me
Not sure yet to be honest, had a quick look at the M3's and don't think they'll be in my price range... Could probably afford em but not sure I want to spend that much just yet.. Won't be in the market til next year though so we'll see..
Gonna be a tough call though, like I said not much really does it for me these days without spending big
I asked for "medium rare" eye fillet the other day and seemed to come out pretty well done :\ didn't really bother me as it was a company expense but still! should of said rare!
no you shouldn't... the fkn chef should be able to cook a steak.
you want med rare, you ask for med rare
problem with the VW sirocco R also is they are only front wheel drive..
same price as a golf R pretty much.. yet without that AWD kinda makes me think.. why did they bother.
exactly...
when I was looking around and thinking about a golf R as a compromise car I just couldn't bring myself to spend the coin on:
a) a car that costs a billion dollars per mod
b) a car that is no faster than an old stock evo
c) a car that detects any fun driving as an "emergency" and kills all power
Sounds like he is wanting prestige based on m3, c63, s5
Heck id say grab the new hsv clubsport/ gts best bang for buck you can get
he said he was thinking 34 R aswell but would spend too much modding it... i was kinda referring to that option.
EVO IX would be my pick...
can get ~260rwkw with basically e85, an exhaust, boost controller + tune which in an AWD car that weighs only 1400kg is pretty damn fast
beyond this the car loses response and starts to suck up dollars so they are easier not to mod than a GTR
a 34R will just end up being a 350+ rwkw moneypit if anyone in vic WL buys one. I know mine would
Do want something with some go...driving an excel/EA since selling my 33 so its been a long time between fun drives.
Leaning more towards prestige/euro... 34 gtr would be good but they're 13 years old now...
As far as evos go they've never really done it for me generally speaking, but if I were to get one I'd say the 8 shape is more to my liking over the 10.
Cars are just shit these days, maybe I should get a Panigale....
Will be properly looking into these supercharger kits for the 86 on Monday. From what I gather: 4-5k fitted, ADR complianced and engineered, all bolt on components with ecu reflash. 170rwkw without an exhaust on conservative boost; not uncommon to get 210rwkw from an exhaust and a little more boost. In a great handling 1200kg rwd, that's good/dangerous fun!
Guest
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
