Just got that fun "go kart" feel that you get from a little buzz box; cockpit interior, in tune with the vehicle controls/feedback. You have to hit the corners though. They are no more special than a sporty little modern-looking car around town. I think they did a good job of capturing the essence of the AE86, being that it wasn't the fastest car at the time (still decent performance), but people loved to thrash/chuck them about. A lot of Hondas like the Integra and Prelude are like that. Would I want more power from factory? Yep. But it stands on it's own where it matters. Be a great beginner track car if you can afford to spend that on a track car.
Add a blower and I think that's the difference between 8/10 and 9.9/10.
Hmm... So for just cruising from/to work with squirting there and there, I'd better off keeping my 34 instead no?
Clever security too :)
Xray machine showed a slight gap near the top of the piston...they got greedy and made the cavities too big.
Depends. In the end it's a newer car, more comfortable and better looking than a Skyline. If performance is what you want and you're driving to and from work, keep the Skyline. Like I said you gotta take it to corners to feel the performance side of it. Without corners it's just a good looking sporty coupe with some nice modern features and interior.
I should be there.
And Dezz e60 M5. Dat V10 noise! Drool!
Awesome! Keen to see your 34, looks dope in the pics. :D
I'll make a post about pre meet tonight for anyone else interested.
Haha bit of wider fenders, plastic dip and some rims and shell be sweet
I considered getting one as a family car in the future. But hear maintenance costs can get quite high if something goes wrong. Especially the gearbox
But I love the sound of a V10 :merli:
need some Neesan help
2 plugs near IACV. one brown, one purple. Mein car has brown plug ok, but nothing to plug into purple plug. and engine-conversion loom doesnt have one nearby that fits. Any idea what they do?
(theyre right next to each other)
Yeah purple is definitely a solenoid, I remember replacing the copper washer on my 25, Not sure what the other bit is but I'd imagine it's probably the part that actually moves to open and close the AAC valve, from memory there's a spring inside that area. Manuals and FAST don't go into any detail about what's what because you're supposed to just replace the whole unit when it breaks instead of fixing them :/
Will be properly looking into these supercharger kits for the 86 on Monday. From what I gather: 4-5k fitted, ADR complianced and engineered, all bolt on components with ecu reflash. 170rwkw without an exhaust on conservative boost; not uncommon to get 210rwkw from an exhaust and a little more boost. In a great handling 1200kg rwd, that's good/dangerous fun!
So a r32...? :P
Looks like I gotta find one to drive and see what it's all about for myself.
Guest
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
