NSW guys also love cock as a daily
with visibility equivalent to this
and $5000 for something like a replacement or repair front bumper, i'd say its not an ideal daily IMO...
he has a 400+kw skyline for a weekender, i dont think many f**ks are given, its reliable and fun to drive.
I'd like to point out that I personally have NOTHING against the lotus or using it on the roads as a daily...
I merely took the opportunity to point out the fact that most N.S.W. men enjoy the penis
cheeseburger society burgers look good... would def try.
also went to Fat Bob's t'other day and it was pretty good. long wait and expensive but very good.
still prefer to eat 2 x huxtaburgers and chips for the same price as 1 fat bobs though
I beleive dezzman is of a similar opinion
  • Like 1
I tend to make my own burgers most of the time cos I am boss and i like to drink beer at home
thus joy of burger trucks, grab burger, home in a couple minutes, drink beer.
I occasionally get beatbox kitchen when in port melb as can be home in under 5 min.
or Mr Burger when in Yarraville and home sooner.
Invite next time please :P
Mr Burger have a shop on Chaps now as well. Have been meaning to go there.
burgers at home are just as quick and easy if you are prepared.
I buy all my fresh fruit, veggies and such from the market for the week and then get 2 weeks worth of meat from Tasman.
I always buy a bulk pack of premium mince and prep it for burgers.
I also go to Breadtop and buy 4-5 packets of savory rolls at a time and throw the packs in the freezer.
These are the absolute last word in awesome home burger buns and aren't even a little bit effected by the freezing process, just in the bags they already come in. they are small though, so you need to eat 2-4 each
The good thing about Tasman is that the way they pack their mince is directly from the mincer to the pack, so all the meat strands (and hence protien strands) are aligned and when not mixed up make unbeleiveable burger patties.
I get the mince and lay the strands (all facing the same way) on gladwrap to be a little bigger than the size of the buns and roll the shit up nice and tight to get a perfect pattie shape but with all the strands facing the same way. using a LOT of gladwrap.... a LOT
make a few logs and throw them all in the freezer too.
this process take like 5 mins at most.
To cook them, just remove from the freezer and once thawed enough cut into thick pattie slices (with the gladwrap still on and using a SHARP knife) and lay on bench to thaw properly and at room temp (doesn't take long after sliced)
heat a thick pan or the BBQ until red hot, salt the meat heavily with sea salt flakes and cook (still with the gladwrap on)
as soon as the gladwrap gets near the heat it shrinks and doesn't actually hit the heat and melt, cook one side, turn over and remove the gladwrap.
cook until still medium... and you have the most awesome burger pattie imaginable
Then I always ensure I have a pack of bega super slices in the fridge at all times (epic American burger style cheese) and can have burgers with minimal notice at any time.
the rest I change up based on what I feel like...
  • Like 1
fark you just made my mouth water you kent.
and ive got a spinach and ricotta pastie for lunch. vegetarian shite.
+1 for tasman meats.
+1 for market food but fark I hate going to dandenong market most of the time. parking + fighting through the crowds isnt fun. Shame south melbourne isnt as close as it used to be :( good boutique beers there too. Cant find Metal Head Porter anywhere!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
