used to go vic market, however have been going here for the last year(ish)
http://moorabbinwholesale.blogspot.com.au/
huge fresh fruit/veg market right near home = winning
burgers at home are just as quick and easy if you are prepared.
I buy all my fresh fruit, veggies and such from the market for the week and then get 2 weeks worth of meat from Tasman.
I always buy a bulk pack of premium mince and prep it for burgers.
I also go to Breadtop and buy 4-5 packets of savory rolls at a time and throw the packs in the freezer.
These are the absolute last word in awesome home burger buns and aren't even a little bit effected by the freezing process, just in the bags they already come in. they are small though, so you need to eat 2-4 each
The good thing about Tasman is that the way they pack their mince is directly from the mincer to the pack, so all the meat strands (and hence protien strands) are aligned and when not mixed up make unbeleiveable burger patties.
I get the mince and lay the strands (all facing the same way) on gladwrap to be a little bigger than the size of the buns and roll the shit up nice and tight to get a perfect pattie shape but with all the strands facing the same way. using a LOT of gladwrap.... a LOT
make a few logs and throw them all in the freezer too.
this process take like 5 mins at most.
To cook them, just remove from the freezer and once thawed enough cut into thick pattie slices (with the gladwrap still on and using a SHARP knife) and lay on bench to thaw properly and at room temp (doesn't take long after sliced)
heat a thick pan or the BBQ until red hot, salt the meat heavily with sea salt flakes and cook (still with the gladwrap on)
as soon as the gladwrap gets near the heat it shrinks and doesn't actually hit the heat and melt, cook one side, turn over and remove the gladwrap.
cook until still medium... and you have the most awesome burger pattie imaginable
Then I always ensure I have a pack of bega super slices in the fridge at all times (epic American burger style cheese) and can have burgers with minimal notice at any time.
the rest I change up based on what I feel like...
Googling nearest Tasman. Doing this next weekend.
oh there. always driven past, never been in. thought it was more about buying bulk food for green grocers. Will have to check it out as its not far from home either. they open Saturdays?
Finally got invited to a christmas function. drinks at Riverland at Fedsquare for the project team im contracting to. Got encouraged to "network"... pfft yeah right. Sink pots till from 3-6pm and then bail. ill be lucky to rock up in a collar. anticorporatelyf
Mmhmmm... this IS a tasty burger
remember to make sure the meat is all facing the same way and maybe a diameter of 1 cm BIGGER than the bun (will shrink when coooked) and to wrap it nice and evenly with a lot of clingwrap
also having an industrial sized 600m roll of clingwrap helps
You mind if I have some of your tasty beverage to wash this down?
christmas part #3 tonight,
no one was all nurses
no two, my upper management so had to behave,
tonight is the office one SO noone from my department or above, will be mainly Asian girls who don't drink so the bar all mine!
A friend of mine was a Mi Goreng regular back in the day, then went off it for ages.
returned a year or so later to it and couldnt believe he used to eat the stuff.
Maccas is in the same boat. i feel ill after a burger so will stick to the icecreams.
government should impose a tax on mcdonalds (or even just big brand fast foods) like cigarettes or something.
Sucks to be you lot; I enjoy my $8 salt meal prepared in 3 minutes. Always hits the spot as an alternative to a greasy ass kebab or souvlaki. It's a frikken burger, why get snobby and hipster over it. Meat, cheese, bun, other shit.
Haven't had Mi Goreng in a while. But I don't have a problem eating it again lol
because better is better
simple concept
better1
ˈbɛtə/
adjective
adjective: better
1.
more desirable, satisfactory, or effective.
"we're hoping for better weather tomorrow"
synonyms:
superior, finer, of higher quality, greater, in a different class, one step ahead;
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
