The fine art of making your boss think that you're on the phone to a customer, when you're really on the phone to CAMS to get your licence number so you can renew it: Achievement Unlocked.
Every 3 months for the rest of your natural business life. Enjoy.
Surprised to see JW in your list Hamish, I thought you hated the stuff. I too vote for Green; it was one of the better tasting from a non-scotch connoisseur. No love for the Chivas or Royal?
I quite like JW. I just think Blue is over priced. It's great and all, but it's JUST NOT A $170 bottle. - you can get highland park 18 for less
I used to drink green but alas it's gone :'(
I drink black as a daily (when it's $37 a bottle i usually buy one or 2 and it hits that price all the time)
Double black is also an interesting drop as the barrels have been charred quite heavily so it's a very individual taste
Also I drink a lot of blends too, i dont see the point in single malt snobbery... some blends are fantastic.
In the last 12 mths approx, i have been through blends - jw green, black, red and blue, balantines nv, balantines 12 and balantines 17, dimple 15, hibiki 17, and a chivas... so it sits probably 1 to 1 to my single malts (if you dont include the JW black daily)
I too don't think it's worth $170 a bottle, but then, I'm not huge on scotch, so to me no scotch is worth that beyond bragging rights of owning the extravagance. I do have two bottles of it though; one was a present and the other I bought because it was a little less than $150 T the time (it was on special and I also knew the staff member at LiquorLand). I have to be in the right mood to drink it; elated over something and celebratory by poolside, or in an anniversary of mourning.
Few years ago I remember the regular JW Black 2 for $50 special that used to appear at liquor stores. Should probably be buying up all these as they seem to be increasing in value over time / over and above inflation.
I'm more into the well to do champagnes, which aren't as good value because they don't last nearly as long and are easier to waste on people who don't appreciate them, unfortunately.
Tell me about it...
have a Belle Époque at home with 2 x hand painted matching chapmagne flutes waiting for the right occasion
Tell me about it...
Was considering buying some at Changi, but had already spent too much on clothes. DP was also only $140AUD ea at the time, if you bought two of them.
The Veuve caught my eye, too. Lovely packaging.
little fridge is cool... used to have all sorts of VC merch as have worked heaps of places they sponsor
Dom is epicly good and would pay $140 but not if i had to buy 2.
used to crack a bottle every week that we made $28k in food and costs were below 25% when I was at Cosi... a deal I made with the owner cos she thought we couldn't do it
once it became regular it changed to veuve though :P
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
