6 months ago I was talking to a Treasury Estate rep who said they were trying to push moscato onto the younger crowd. I made the prediction that one day it will make it's way into nightclubs as an on-tap, women's counterpart to the men's cider craze. Canning it is half way there. I wonder if my prediction will come true...
I confess to liking moscato and late harvest. If I recall correctly, it was originally pushed as a nightclub/bar drink but never took off. Maybe the timing wasn't right or they didn't have the marketing of today.
Juliette has seen it on tap already....
I understand sharing beers regularly, but drinking beers every night is a pretty bad habit. i know a few of people who drink almost 3-6 beers every week night, and they see it as ok because tradesmen and because alcoholic. But living a hater/hipster/father lifestyle, I thought of it as an oddity.
no, it's an awesome habit... because beer is awesome.
Been on the Oetty's for a while now
http://danmurphys.com.au/product/DM_914086/oettinger-pils-bottles
$29 a slab and I drink a slab a week
based on DM's full price for draught that's a saving of $830 per year for a better beer with no preservatives.
f**king win
Ok, off to dm's
But still need to get moar cash for a plane ticket to Germany for Augustiner Brau.
the cans are a surprise.
but i do like their moscato. pretty pricy though
farkin alvin, moves his dinners so some one can go, now i cant go! ya big bummer!
nah all good mate, ill chat the next one.
So I went looking for some new and engrossing movies to watch and came across this list... then realised that I've seen about 90% of them :/
http://couchpopcorn.com/2012/10/02/20-best-mindf**k-movies/
I've just gone though a comedy phase, and then a infection (non-zombie) phase and now sure where to go from here...
I'm thinking of hitting up all of the Studio Ghibli collection, unless you guys can suggest something that I just should not miss out on seeing. I don't like slow movies, so if its fast paced and engrossing I'm into it :)
k go...
i like slow movies, so cant really help. sorry.
in other news, if Aus did industrial estate sprints, i'd give it a go
I fall asleep or get distracted too easily for slow movies...
Good luck getting a permit for that on the streets, glorifying street racing in industrials would bring all the boys (in blue) to the yard.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
