Your ass getting sore from sitting on the couch (yes sitting on the couch, I'm not implying anything else) this summer...
List of SAU VIC Events for Q1 2014.
http://www.skylinesaustralia.com/forums/topic/437237-welcome-to-2014/
No excuses, I'd seriously be putting September 28th aside btw.
well now FPV is dead, the GT motor coming out in the XR8
so priced just over 40K new.
oh the 335, it has an over boost feature so if you give it a prod it does 375.
that's some bang for your back.
and considering the 2 AU built cars I've ever owned have been the ones that fell apart more than any other, great engine or not I think I would pass.
I'm sure when the FPV were done "bespoke" they were much better, but now they assembly line things, meh.
got a hint for us richo?
40k for the 335 supercharger engine? if the interior is elevated above taxi spec this would be fairly awesome - not a massive ford fan but that engine is amazeballs.
:wub: ham!
I've got heaps of spare hubs if you want one huy
Got to see if the other ones are broken or not, not too promising when two studs on one is broken.
Richo, will post photo of tyre later tonight.
one, more, have a pair of fronts and 2 pairs of rears I'm never gonna use.
i maintain my opinion that the new 5L ford engine is awesome. so easy to make power out of it.
oh I agree with this part
my mate may have one for sale as he is shooting for 1000hp and using a crate engine if your interested :P
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
