How many litres did you fill it up with? I'm guessing around 50 litres, in which case that's pretty normal economy for a Skyline. And if it hasn't been done, changing the oxygen sensor can help your fuel economy. But I wouldn't be bother if you net around 400km from 50 litres.
A light will come on when the needle is near the E and you'll still have 20km or so left. It's a 60 litre tank.
When i filled it up it was on the 2nd last bar, i filled it up all the way with 100 octane which costed me $65, i think i got around 35 litres before it wouldnt go anymore, it was $1.65 per litre and i put $65 in, so whatever that adds up to is how much i filled it up before it wouldnt go anymore.
My sender is acting funny also.
Haven't bothered to clean it, as long I get at least 400km out of the tank s'all good.
I've managed bit over 500 on a tank before fillin it up today.
Your fuel economy is fine for an N/A 2.5 6 cylinder of that age. If you used 39 litres and got 350km, that's around 11L/100km.
I don't think your fuel sender is terribly inaccurate either. If you assume that half a tank is 30 litres and you were on the next bar, 39 litres isn't a stretch. There's still a good 7-8 litres left after the needle touches the last line.
I wouldn't worry about running out of fuel until your fuel light comes on. It's a bit past the last line on the gauge, just before the needle touches E.
OP6 vs 21U housing - do they share the same bolt pattern and distance from flange to firewall? Thinking of buying a blown 34 turbo to highflow to net an extra ~20hp headroom.
Same bolt pattern, not sure about distance, but it doesn't matter, cause OP6 has been fitted many times without issue. If you're going through HG just give him a 2IU housing and get an SS1PU.
  • Like 1
Might pick up some injectors tonight.
If so, that's pretty much everything for first round of mods! Will just need to install all the parts + tune. Yayerr. :D.
Although still deciding whether I have enough cash moniez to also grab aem afr/boost gauge.
Doesn't the SS1PU push the exhaust back even further, or has Tao fixed that? Have you had any long-term issues with yours?
The SS1PU pushes it back further because it's a new turbine housing, not just a high flow of the stock housing. I've had no clearance issues issues, there was plenty of room for my exhaust...still is. Air con drip hose (?) was slightly touching the dump pipe, but I tied it back and it doesn't contact anymore.
Will do a detailed post in the HG thread later today to kill some myths, as I've seen a bit of garbage posted in there lately.
..Will do a detailed post in the HG thread later today to kill some myths, as I've seen a bit of garbage posted in there lately.
Yeh that would help a lot, there are so many conflicting statements made about that turbo.
Post up your setup+results to go with it
just went to look at a new GTi.
I could not believe how bad the service at the dealer was.
avoided answering questions. fairly simple ones.
ME: when the performance pack is coming out,
THEM: OH GTI's are very popular you will need to put a deposit down to get anything.
ME: what is the lead time if I want XYZ
THEM: Oh you should be happy with any we can offer you as they are very popular.
SO I had looked on their site and they have some optional wheels that I liked more Lighter and wider.
ME: How much are the wheels I saw on the VW site.
THEM, oh I couldn't option them, the normal ones are too popular, you could get them from the spare parts department later if you wanted but we could get you some cheap tyres to put on them!
ME: How much is the sunroof on one
THEM: the GTI is a very good buy as they now have capped priced service.(!!!)
ME oh ok how much is the capped price service
THEM, OH we have not set the price yet but is is sure to ber very cheap. I can tell you the price of the Series6 GTi but it won't be the same.
so frustrating.
Guest
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
