everyone please be conscious of electricity usage today, mk. Thanks.
Currently work planning for some upgrades near the Eildon & Rubicon hydro power stations. Transformers here were installed in 1914, getting ripped out this year. Will make sure to give them their letter from the queen. That shit is asset sweating to the max. Never even heard of equipment so old, even in the UK.
Could secretly be the Decepticons
Stay safe when playing with Transformers
what are the chances the replacement gear fails before that old gear would have, even if its inefficient and 100 years old.
its more of the case the old gear more likely to essplode during peak loads like on day like today. and the things are leaking oil like no tomorrow. (its all bunded, but dont tell EPA)
replacements could be decepticons. Will have to ask before they get switched on.
Jebus
Dashcam of the crash the other night on Princes & Warrigal road that killed a pedastrian and people in the car
https://www.facebook.com/photo.php?v=645922298800747
that f**king brutal.
whats the story here?
pissed? in a hurry, didnt see the light what? or is he just a murdering thunderflamin mongrel.
Yeah not good
Story is here, happened Sunday night i think
http://www.heraldsun.com.au/news/triple-fatality-at-the-intersection-of-warrigal-and-dandenong-roads-in-oakleigh/story-fni0fiyv-1226800271810
wow. cvant just be stupidty. drugs? booze?
Not sure haven't read into the story much, but seems as tho the driver was being a dick before hand
"Witnesses have told us they were overtaken by the Kia, and saw it go through an earlier intersection where the lights flashed."
Jebus
The road was still closed when I went through it in the morning as well.
Terrible.
Thats shocking. also a terrible article, I still have no clue who was where, who was driving what car or if they even knew/caught the person responsible.
on a lighter note: only time I'd probably own an Evo/engine
http://www.my105.com/ListingDetails/tabid/65/p/2/cid/612/id/10912/Default.aspx
Wish that dashcam video showed the point of impact and aftermath. If anything, would have worked just on shock value to show all the morons and airheads out on the roads what happens when they run reds/don't pay attention etc.
Those TAC campaigns show all the gore and shit, and it's all just manufactured to teach people. Using a real example would really hit home I reckon.
I think out of respect for the victims families it's not really appropriate
Yea I can see your point. I guess a good analogy would be an organ donor: the ability to prevent another's death through a life lost . Showing people the real deal would be more effective than showing some scripted CGI commercial which everyone knows isn't real.
^this @L33SH
I've seen a few fatalities on the roads and stopped with my old man to help before emergency services have come, it's pretty disturbing for someone that has no relation to the victims let alone a family seeing it
Guest
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
