I need to install a double din head unit, speakers in the front and back, a sub and 2 amps, anyone know anyone/place that installs all that for a good price and does a good job?
I asked jb hifi how much to install all that and they said $650, even i know thats a rip off.
f**k that for a joke. $200 is a metropolitan tow, assuming you even need one once a year lol
applies to every car you drive though, so if you're in a mate's car....
or if you're like me, leaving them headlights on ever so often.....
I agree. Biggest rip. its for people who dont know how to change a flat, jump start or cant stsrt tge car when its flooded. Other than that, its a tow from regional areas.
Also, can use for other cars ONLY if you upgrade cover to a higher level. Which was quite pricey... I got missurs to upgrade for 1 month when we drove to NSW, then downgrade.
You've driven mine, at 270rwkw it only just hangs on to 2nd gear with quality 265 tyres and the 1.5 way. E85 powered turbos come on fast and strong; you'll definitely want those 285s! I'm still very happy with my power for a street car; no desire to upgrade or change it.
That being said, a good right foot controls how much boost you get, so you can always go all out on the tune (within the limits of the clutch) and train that foot. Are you going to have a separate 98 tune or is yours a flex tune?
Gearbox tolerance for power is a piece of string...plenty of people pushing your power levels through these boxes safely; they handle a lot. Others can break the a box with standard power. This is where not so grippy tyres and a soft clutch are your best friends.
This... With 290rwkw @ 1.4ton on 98 I ended up ditching e85 for street duties as it had more than enough.
e85 only for special occasions lol
If only this one wasn't nearly 5k over-priced. Has D1R's with it tho.
http://www.carsales.com.au/private/details/Nissan-Skyline-1998/SSE-AD-2427313/?Cr=19&sdmvc=1
that looks dodgy as, why not even wash a car prior to posting pics for sale? dirty as engine bay, why need 3 air fresheners
plus 13500
ha
  • Like 1
350 minimum.
Yeah went in for a tune on 98, came out of the shop with a e85 tune lol
Yeah might just end up using the 98 map mostly if its too much power for me
your 98 map will be spastic anyway lol
my issue was cruises etc, and that I was using manildra e85 which is only available from one place.
If I go e85 again it'll be united
EOTD they are light cars, and as such 300rwkw is a LOT for street.
they don't actually need 370rwkw just to move them like leigh's cruise liner :P
Yes will be interesting.
On the old turbo i got bored quickly on 280rwkw.
Also an issue with the old turbo on the track was the powerband, sure it came on fullboost at 4,000rpm but then it would run out of puff at 6,000.
New Turbo should give a much wider powerband of 4,500 rpm to 8,000 rpm
Will have to take on leigh from a roll on the new setup once its finished :D
Bitch plz, put me on a hub dyno I'll be making 500rwkw trollface.jpg (nah but srs "430rwkw supra" made less than mine at a certain dyno day.. didn't crack 350 at chasers)
Bring it on! definitely more chance on a roll though that's for sure I've gone my brother a few times from low speed I'm gone by the time he boosts or he just hits boost and wheel spin city cos of the light weight 33 :P even with AD08s it just skates in 2nd sometimes the extra weight helps just squats the car down and grips.
Ofcourse we shall be doing this in a legal environment / on the strip :) but yea I'd imagine you'd have me on roll if dat power is legit
Edited by UNR33L
Gooby pls... I said brake boost.. he'll be on boost before you hit the loud pedal and your taxi just be a dot in his rearview mirror.
Gooby pls, propper 1/4 race from the line :)
My brothers got a GT35something in his, thing don't make boost until 6000rpm!
your brother isn't tony...
4500 - 8000k
you will lose - then be fined for fog lights
face it
Yeah what Hamish said. Im making full boost ~22psi at 4,500 rpm
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
