such troll, many anger :P nah but srs 8k rpm is nuts should be amazeballz shouild be a 10sec in that with the right setup of suspension / tyres / clutch (not that you care about the drags really)
Lee, just kicks in straight up and holds boost the same level throughout whole rev range basically
Edited by UNR33L
Yeah can't say I've ever been keen to enter a drag day
Happy to drag you down the Sandown front straight as some of the other boys do :P
I agree. Biggest rip. its for people who dont know how to change a flat, jump start or cant stsrt tge car when its flooded. Other than that, its a tow from regional areas.
Also, can use for other cars ONLY if you upgrade cover to a higher level. Which was quite pricey... I got missurs to upgrade for 1 month when we drove to NSW, then downgrade.
I had RACV roadside when I was 18 years old. Crashed a car, called up to get a tow. They said sorry can't tow you for accident, only if your car is broken down. I said I can't drive it, it's broken down, I need a tow. Sorry, not for accidents.
Canceled membership there on the spot. Useless dream boats.
I forgot about that, Birds. Also happened to me when I was 18.
jealous of Tony atm. my manifold hasnt arrived yet :mad:
car heading to workshop on wednesday for intercooler piping and other works. need to decide on BOV, catchcan and coolant reservoir. cbf. can forsee it now: ill buy something and it wont fit, or be too small or something much more suitable that i didnt know about etc.
Thats the problem with "generic" or misc. items. never sure how much effort you need to go to to fit stuff. and oil fittings... fark that shit. a world i dont want to get involved into.... stupid imperial and pipe measurements.
Tony could beat Leigh with some serious grip and a drag friendly suspension setup. Need MT streets or something.
Then again, hub dyno, Leigh might just get him even with traction.
Bed-Stuy, the place where my head rests
Fifty shot clip if a n***a wan' test
The rocket launcher, Biggie stomped ya
High as a motherf**kin helicopter
see you THOUGHT I was gonna do that
Leigh's car WISHES it was tuned on a hub dyno...
you wish your car was tuned on a hub dyno
hub dyno
Dyno dynamics is how we roll
not me... I prefer accuracy over wheelspin
of course in saying that my evo was tuned at chasers...
on a dyno dynamics...
and has no where enough power for wheel spin...
Guest
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
