Ma Nigga
No wedding for me. No kids either
Just $$$$$$$
666e8b064728e9605e3fd677083ab3ea87bc6727
You got a house to yourself yeah? you best be making a 'games' room with a big ass pool table, bar, etc.
Edited by UNR33L
  • Like 1
Ma Nigga
Just $$$$$$$
do you wonder if life may be unfulfilling without family / kids etc?
not having a crack just curious
i mean i never thought i'd have or want kids etc but i dunno the older i get i think it would seem a bit pointless
Edited by alr33x
ditto.
but fark marriage. de facto all up in here
once i found out youre supposed to get an engagement ring AND a wedding ring... it was the nail in the coffin
Got a poker room but rarely play these days
The way I see it I'm too f**ked up to be in a relationship and definitely not a good candidate to be a father. It's not really a choice just the way it is, so no choice but to accept it and get over it. I'll just have to find other ways to make it fulfilling, most likely with material possessions
Kid I went to tafe with had a VL, got a small branch caught underneath it and it fell out just as he went around the corner then stopped to investigate. Watched him poking around down there for like 10 minutes before I put him out of his misery :P.
its still run in.
we'll see what happens with new turbo. will probably rev limit at 7800 or something, wont be much torque up that end but cams will probably be still going.
but used to be
I used to think same... but EOTD it's something you will want eventually as we are all programmed for it.
after all it's the ONLY reason we exist.
In my mid 30's now i am starting to see a lot of my mates without kids starting to say they wish they one after hanging out with Orlando
Orlando is pretty fkn Rad though
Guest
    • full send the cnut, do this   fark the wrapping and/or stick on siet.
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
    • Finally had these painted and fitted and pleased with the result. also managed to source 400R fender badges.
