That 33 looks ace. Surprised the white wheels work well with the grey. And he didn't overcapitalise by spending more on rims than the car is worth :thumbsup:
Or modifying a Pulsar...
I'll reck ya kunt
How much is it?
I thought about just going to the PI after parties, as I was down there last year and it was going off at night lol
It's late entry atm, so will be around $200.
It can't be that much of an achievement if I was able to complete lol
Haha! For me, at the moment, I think rather than completing it as the end goal (which, all the same, would be nice to accomplish), but would like to focus on just as (a) something fun and active to do with some mates (b) as added motivation to train; been a bit shoddy lately and not happy with that. Also perhaps a chance to train a bit of functional strength as well as endurance/cardio (which I'm generally not a fan of... feck cardio). But good to boost fitness levels.
Obviously you could not to do this, save $200, accomplish both (a) and (b) in other ways, but that's sort of neither here nor there, really. As with everything in life, lol. Always about options, viewpoints, status quo, etc.
Give me 20 D Energizers.
20 C Energizers?
Not C, D.
C Energizers?
D, motherf**ker, D. Learn to speak English first, all right?
How many you say?
20, motherf**ker, 20.
Motherf**k you.
Motherf**k you? You, you all right, man.
Ishan I think you want to spend the money because you perceive better value from having purchased an experience.
No idea, I haven't been stepping for ages. With basketball and squats, my legs wouldn't let me do the steps.
Guest
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
