standard falcon power brah
Here you go:
https://www.facebook.com/NemLozo
see I got dem ford connections brah, he's part of one of the facebook groups I'm in - don't know him though.
nuff said
1545034_10152624513835715_866942462_n.jp
lol thing is fkn quick tho, hit boost car went sideways with ease.
anyone watch the new top gear ep? P1 seems to be mental
yeah the p1 looks awesome!
i saw their nurburgring lap like a month or two ago and been wanting to see more of that car!
6 year old JAG wallet brah checkin in
Don't feel the need to change it either, never been one really for fashion tho
i think i got my JAG wallet back in 05. still trucking, the only bit that failed was the plastic in the ID card slot.
looooool - clearly not the sole reason for cessation of production, definitely played a part
remove head - fit ARP studs - replace head with new OEM gasket - strong as houses
Dinner and Bistro Vue then hotel
not even...standard headbolts will suffice as long as threads are tapped clean and correct (not OEM) torque is applied and retorqued after 1000kms or so.....its around 75ft/lb instead of factory spec'd 55 ft/lb iirc...
the original design was based around an asbestos HG...new laws disallowed this at the last minute toyota had to change their gasket design to not contain asbestos....unfortunately this meant the torque specs should of changed but with no time for RnD on the new gasket it didnt happen...so the average lifespan is about 100,000kms.....OEM Headgaskets have been redesigned a few times to help solve the problem but (some) aftermarket gaskets have of course copied their design by now so most quality branded ones will work fine.....The real issue is in the torque specs...
and that concludes todays lesson on ye olde 7mge boys and girls...
real life.....
roses are red.
my hsv is blue.
i was going to buy you something.
but i spent it on fuel.
its funny coz its true :rofl:
I watched an early season 1 episode, where they briefly discussed GTR's and came to the conclusion that the 34 GTR is the best one, but the 33 was best value for money.
The 33 and the 34 are 90% the same, biggest differences being the wheelbase, attessa computer and gearing. The rest of the differences really come down to personal preference though I think we can all agree the interior trim and general build quality is better on a 33.
Well it does make sense, BBC is heavily controlled by the UK Government, so there is def some political motives to promote UK brands and keep local production alive...
Top Gear Australia: Votes Toyota Camry #1 Car in Australia
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
