I don't really care I flog it anywhere now, dat non import lyf
fkn this.
I gave up caring when i got my SECOND speeding ticket for less than 5km over.
if they are going to book me anyway, I might as well do what the fuck i want
Not that I doubt Damien's abilities, but unless he can add a 4th dimension to the universe, I can't see the reflection being any deeper/better than a pure mirror :P
Artz and Birdz detailing ftw
looool
Don't you have an r33? You'll need side feeds if you aren't doing rail conversion
This. The ID website said the ID2000's are for RB25/26. huh?
I've heard 1000cc + injectors can cause idle issues using a PowerFC on PULP? Of course if going e85 I'll go ID's..
I've got ID1000's and it did have some idle ups and downs occasionally with PowerFC, but that was with trents tuning (wasnt harmful or anything). Been elsewhere and havent had the issue.
Id1000 brah checkin in
Go big injectors and do it once
You'll eventually upgrade in the future and want headroom if you ever go e85
Dino fuel lover to e85 guru in 1 tune session. My work here is done. :P
weird. he knows exactly what causes that and usually corrects it... was he in a rush for that tune?
Guest
    • Updated with the latest <68mm Xona Rotor turbos.  The two XRA options are on paper some of the compressor performance I've seen
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
