Between that and cams it would almost shut off at 800rpm
Cams can affect vacuum to the extent it is difficult to idle, good chance that was your tractor's only issue, other than the driver... :P
My 1000's idle perfectly.
It was probably more so cams but only started after injectors.. Either that or Cihan lol
Bosch 1000s checking in.
Although they're still sitting on my desk, and not installed, XD.
I was going to get ID1000's as well though. Although they're really the same, I think, just flow tested or whatever etc / up to you whether to believe marketing.
Dino fuel lover to e85 guru in 1 tune session. My work here is done. :P
Lol well I was always going to go to e85 just not so soon.
A bit unexpected when Trent says ok lets do an e85 tune whilst where here lol
Going to Daylesford next weekend. Thinking of putting an e85 jerry can in the boot just in case :/
got an email from commbank. theyre phasing out signed transactions, all cards must have a PIN. a win for security yay.
in other news:
http://theage.drive.com.au/motor-news/classic-corvettes-swallowed-by-sinkhole-20140213-32j5b.html
Yeah mine has hunted a bit as long as I've had the car... ever since before the PFC went in (had a Mines ECU beforehand)... It just bounces harder with the PFC I think because it's more aggressive at trying to recover from a low rpm...
With the A/C on, sitting in traffic, it'll sometimes start bouncing 600-1200 rpm with a 2 second cycle... Can see the vacuum levels are fine, but obviously that looks like its bouncing too with the change in rpm...
Guest
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
