If listed all the go fast bits on my car, people would think AMAGAD BUILD THREAD??? but it performs rather.. averagely.
Not bad, just averagely.
It has Tomei type B's in it (engine is 2.8L), adjustable cam gears, and I'm not 100% certain that it's all the way it should be. It probably isn't actually wrong, but I doubt it's completely right so it'll bug me until it's checked.
I've also read many places on SAU that having an adjustable exhaust cam gear is of benefit. So I got one, with my cams, and no one has ever actually adjusted it to see if it does anything. Just a "she'll be right mate its designed to be on +0" in which case why even make the item?
Fair enough, have you had opinions from the tuners etc..?
Is it currently with a reputable workshop?
Curious to know which one its at. PM it if you want to keep the workshop private
bahahahah.
they are race cams for the 1.3 in the micra..... going stupidly cheap. but i dont know enough about duration/lift etc to even contemplate buying them....
I could ask a mate if you REALLY wanted to know....
bahahahah.
race cams for race head or just OEM head???
If OEM will certainly requiring machining. That's about all I know.......and IF I'm wrong well my disclaimer is this.......kiss my French something something dark-side :P
i have consulted the guru of all that is micra.
ghettofrank.
hopefully he should get back to me when he wakes up, but from what im reading your right ants...
this is tomei poncam spec. http://www.rhdjapan.com/tomei-camshafts-procam-poncam-cg13de.html
the engine it came out of must have been mental.
just be wary: procam is for solid lifters. poncam is for hydraulic. anything bigger than 280-290 degrees... you'd want solid.
Dont know much about those engines, but cams that big is like "I need to wait 15mins for my car to warm up before its possible to drive it under 40km/h" and the "my car doesnt make power less than 4krpm"
thanks man. will leave them the f**k alone then.
Seems to be some car enthusiasts on my street, there's been beemers, mercs, and now micra project cars in the carport.
give that micra kent a shout and see if he has any parts!
where you live?
Who needs a daily?
I have a workmate selling a 1995 integra Type R for ~ $2k with RWC
f**k me your kidding?
would have loved that 3 months ago.
prob would still buy if i had sold the clubby.
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
