According to the Age:
http://theage.drive.com.au/motor-news/first-drive-toyota-86-20111128-1o1vi.html
'Less than $40,000'
But at 140kw, I don't know man. Maybe a car for the missus
hmmm, power-to-weight ratio is same as a stock r32 gtst.
Im keeping my eye on it as it will probably handle and feel like my r32 but with everything being new and not rattling/falling apart haha
If someone comes up with a turbo kit for it, it should be pretty good. However, I would have prefered to have a reliable Toyota engine...
Give it 6 months from new, there will be a kit commercially available. Will seriously consider upon test drive...but I did see a late model Celica today and it reminded me of the 86 quite a bit :(
I knew Toyota would have to make something bland about it...why did it have to be the engine :(
Plan for Jan 2013? :P
it just needs some phat wheels and stance to be epic imo.
with a turbo would be so awesome really hope they bring one out down the track a trd version or soemthing.
for sub 40k it has no competitors i mean a 370z is 70k new!
Gardening is a pain in the arse.
Redoing my small backyard, massive front yard and side yard.
Progress of the back so far. Before and after
Front is a blank canvas at the moment
sheesh, that looks like a huge property? Demolish and build units?
UK ain't all it's cracked up to be. Their petrol is ridiculously expensive and enjoy your rego on anything with more than a 2 litre engine...then there's the ugly, fat and depressing lifestyle/weather.
Import from the states = $30k to do a proper conversion from LHD.
It's not as easy as it sounds; for every loophole you can think of around paying high prices for cars locally, it's all been thought of / done before. This is reflected in the prices of our local second hand market and the overseas import markets. It's the reason why you can go to Japan and buy a 1998 RX7 for $9k, whilst a 1999 RX7 will cost you $18k - the latter can be imported to Oz.
Buy a delivery km Mustang in Australia for ~70k-80k, the same car will cost you 35-40k in the US...add your RHD conversion, shipping etc. You might come out 5k better off after the hassle and risk involved in importing yourself.
Personal import is probably the only thing worth considering to save money, if you can pull it off...
Die in a fire!
mmm love the old school americans
old man owns 2 68 RS camaros (one driving and other one about to be restored) and a 57 chev belair (being restored atm)
And that Yenko will snap a speedo in about 5 seconds flat
also cost you $300k plus :P
I could design the front if you want >:| I has the programs to do so. Hehe.
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
